1 - 2 of 2 Posts
Alright guys I am trying to stuff 33"x12.5 R15 tires with wheels that have 3.75" backspacing under the Colorado
I have a 2006 Z71 4x4
Here's what I am thinking please help,
Rear Suspension
-Skyjacker H7084 Shocks
-3" Shackles
-Pro Comp 13120
Front Suspension
-SuspensionMaxx Ball joint flip and spacer
-Home Depot 3/4" diff drop with washers and stock bolts.
-Rancho RS5375 Shocks
-2.5" Torsion bar Crank
Do I need to upgrade the struts at all, and if so what?
Is trimming the body mount safe?
Should I get reindexed torsion keys, or is that unnecessary?
Please help!
Skyjacker or Rancho 4" subframe suspension lift would work. I ran Skyjacker on my truck and did not regret it.
Trimming the body mount is a good idea if your tires are rubbing on it, and I would recommend welding in a plate after you have trimmed it to cap it back off. A 1.5" body lift is a cheap way to get more fender clearance.
1 - 2 of 2 Posts
