New in BoxPART #: NFB-G154RKRCCS4
Fits 2015-2022 Chevrolet Colorado or GMC Canyon Crew Cabs (confirm fit prior to purchasing)
Description
* RKR Step System includes a pair of RKR rails + detachable RKR steps
* Built from 1.75" diameter steel tubing
* Treated inside and out and finished with a textured black powder-coat
* Welded 1 piece construction for strength and longevity
* Bolt on design is engineered to resist flexing
* Made in the USA
N-Fab RKR Step System are the perfect slider for your truck! They are built with 1.75" tubular steel that is .120" thick for superior strength and durability and have been fully treated inside and out, then finished with a textured black powder-coat finish that resists corrosion and looks great on any vehicle! These bars are sold as a pair and have a bolt on design that is easy to install and won't flex when put to the test. To make this slider set even more functional, they include bolt-on RKR steps that can quickly be removed before hitting the trail, so you can maximize your ground clearance. Once you are back on the road, they can be re-installed just as fast to provide you and your passengers that much needed step up, making entering and exiting your vehicle much safer.
pm me
