221 - 240 of 265 Posts
@KEVINMWARD I wish it was that simple (a return). The version I received does have 2 holes in the hitch tube and the correct latch position. I confirmed the version by phone with the owner before ordering. The manufacturer has twice replied to my emails suggesting "the easiest thing to do would be to modify the hitch receiver on your rig." My truck is relatively new and I am ignorant of how modifying the receiver would affect warranties... I am out of state on a work project for several more weeks but when I am home I will look into removing the wob-not mechanism and drilling a new hole in the hitch tube on the swing arm and using shims or something to prevent wobble as suggested above.
Lets retire this and return to thread to the original poster and purpose! I look forward to seeing more progress of the build!
@BisonPlus
Your making me nervous now loll,i ordered this a few days ago and ordered the same multi-fit use , i am not to big on drilling into my truck either as they said it was supposed to be plug and play basically . i wonder if it was a production error error or on the one they sent you or if it was just because of the bison bumper, i believe he had a zr2 not bison. Theres another guy on a Facebook group who installed it. i had sent him a message about his install and he said it was smooth, didn't have any issues. that's strange. Im trying to find the thread now where is spoke with him
@BisonPlus
@KEVINMWARD It is entirely a bison bumper issue. I was just disappointed because I had received some bad information that all I would need to clear it was delete the passenger rear recovery point (which I did before having the swing to measure for myself). The current clearance issue is with the bumper's rear tube only. If you don't have the bison bumper I'm sure it will work great!
Discussion Starter · #224 · (Edited)
Wow... it has been awhile! But rear lights finally installed... went with inexpensive knock-offs for now. Will get the real Baja Design (like I have in the front) later.
398122
398123
398124
Looks good! I just did something similar, but have not yet wired them in. Thinking I;ll use the pigtail for the cargo light.
Reactions: wachuko
Diode Dynamics now also has pod style lights that would be an upgrade, including a Pro series that should be on par with BD, and they have sales more often than BD does.
Discussion Starter · #227 ·
I thought about wiring them to that switch... I have the LED strips in the bed wired there. But it was easy to wire them to the backup lights.
Reactions: 93Duc
Discussion Starter · #228 ·
I was not aware... will check those out. Thank you
As a follow up- I recently had a Hitch & Trailer (& custom fab) shop assess the ultra-swing/bison rear bumper situation and it was decided the easiest thing would be to simply grind off the small amount of metal blocking the pin (1/8" or so); leaving the factory receiver intact. With the pin in and wob-not secured I can't budge it.. and for now I left the small felt pad between the ultra-swing and tube of the bumper (I'll probably replace with silicon or something not inherently abrasive later).
I decided I will need these lights mostly for hitching/unhitching trailers, so I didnt think reverse would work for that. Be nice to have either option.
Reactions: wachuko
Discussion Starter · #231 · (Edited)
I hear you... These light up the night nicely... I might just change them over to the bed light switch. The best would be just to have an additional set with the switch and keep this with the reverse... I just know that I am glad that I finally got them installed.
Reactions: 93Duc
I hear you... These light up the night nicely... I might just change them over to the bed light switch. The best would be just to have an additional set with the switch and keep this with the reverse... I just know that I am glad that I finnally got them installed.
This is something moving up in my priority to do list. Are the lenses on yours diffused or clear? From the pics they appear clear.
Discussion Starter · #233 ·
Reactions: 93Duc
I went with the Datin bed rack and over a year later I am very pleased with every aspect of the design and modular flexibility it has.
Reactions: wachuko
Discussion Starter · #235 · (Edited)
Do you have a bed cover as well? Problem/challenge that I have is that I want a hard (retractable) cover as well... The cover I have now, the segments, would require that I have a pretty tall rack with very little angle on the sides to clear the cover when opening...
Well, I do not want a tall rack... I want a mid-size... but it means changing to something like a retractable cover...
That also means that the way the bed rack installs it needs to clear the retractable bed cover...
I know all this means that I will loose some space in the back and will have to remove the canisters from inside the bed... but those would then get moved to the rack.
I have always liked the looks and flexibility of the Datin... the problem is installing it without having issues with the retractable cover...
I don’t have a bed cover, so yes I can see the challenges there. Ed does have a custom option that might have the ability to customize it for your needs. Ed is also accessible and I’ve found easy to work with. I’m not affiliated, merely a satisfied customer.
Here’s a link to the custom option:
Reactions: wachuko
I'm currently looking at the same RIGd Ultraswing tire carrier. I'd love to see your final result was, if you don't mind? Thanks for documenting this. It's extremely helpful for us Bison people.
The shop did a hurried job- could have been cleaner.. but here is a pic I took when I removed the multi-swing to paint/clean it and vacuum the shavings (first image). It didn't require much extra clearance.. I may clean up the hole in the future.. but its not at the top of my list. The only pic I have of it on the truck was taken Friday while the wrap install was in progress (Avery's Satin Metallic Dark Basalt if anyone is curious; wrapping because I already have way too many paint chips). I haven't installed the wheel mount and moved the spare yet (waiting to finish wrap and other mods).
400675
400676
If requested - I can try to take pictures from above the ultraswing, etc. tomorrow after back from the wrap shop to show the space now that its pinned and secure (same gap/snug fit as in the first fitment pic).
I'd love to see those, if you have a chance!
