1 - 20 of 21 Posts
Been a long time since ive posted, the last time was actually when I purchased my truck.
Since then I have lurked a lot and done some work to my truck, I figure its a good time to post some updates and future plans.
378050
Since my last post I have done the following:
-Air dam delete.
-Lettered grille installed,
-White tailgate bowtie (not pictured obviously),
-Ditch lights installed,
-Softopper.
Future plans:
-New wheels and tires
-leveling kit
Welcome! If you do decide to ditch the side steps, you should not have any problem selling them. I believe that may be the first set of side steps that I have seen on here for an Extended Cab.
Reactions: 1337sp34k3r
Super Moderator
Those are steel wheels right? Have you thought about painting them black? If you're going with an aggressive tire then steel wheels look pretty cool!
Discussion Starter #6
Revisiting this while its on my mind, honestly thats not a bad idea. I always did like the utilitarian look of stock steelies. I probably wont go through the effort of painting the whole wheel black, but at the very least im pretty sure Im gonna be painting the center caps black pretty soon.
I thought that I was the only person out there that actually likes the steel wheel look. I did see a truck with the steel wheels painted black and they did look nice. I think that he left the centers stock. A black center on the ardent silver wheel would probably look neat.
For a WT, that truck looks nice and coming along well.
There is nothing wrong with a WT! Lol The best decisions I have made both with my 05 & 19 is starting with a WT because it allows you to make something unique and build something custom for your needs without a higher truck note. ;)
Nice looking work truck. I had a 1" leveling kit installed but wish it were 2". What happened was I wanted a 2" but a 1" was mistakenly installed. They said a 2" will wear out joints faster. I don't know but kept t 1". Together with the air dam removed mine looks much better also. What you might want to do is paint the pinch welded sheet metal under the doors black. I did it on my silver LT and adds a nice tightened up look.
Nice truck, you can do alot with the WT. I have a 2018 WT. Have 2 inch level, 1 inch rear block and 1.25 inch body lift. Removed airdam. Added KO2s tires and added fog lights. And some other things. Have fun modding it.
Discussion Starter #15
Recently I have been considering getting a 1 inch rear block and a body lift just like you described. What size tires do you have with that setup?
Discussion Starter #17
I keep debating with myself whether i want aftermarket 16 inch wheels with 265/75/16 tires or 18 inch wheels with 265/65/18 tires... either way I have already trimmed the fender liner plastic so my wheel wells are all set for lower offset wheels and slightly bigger tires. Wheels will happen soon during the summer so I guess just stay tuned.
Discussion Starter #19
Update: sold my softopper a few weeks ago. Now I am looking to get a fiberglass camper shell with a roof rack/basket on it.
I did just that and made a whole removable setup in the back for escaping into the murky fringes of society camping.
396679
396680
1 - 20 of 21 Posts
