1 - 8 of 8 Posts
Super Moderator
Yes but you'll need a custom made wiring harness, LS bell housing and input shaft for the trans(if automatic) or LS adaptor plate for the 5 sp manual trans e40 pcm(if you're using a gen 3 5.3l), gas pedal from a v8 trailblazer, ac lines,power steering lines and maybe the oil pan from a 2009-2012 factory v8 colorado/canyon, ls motor mounts, you'll need to "massage" the firewall a bit to fit the 5.3L.... I'm sure I'm missing some things
Look up Current Performance wiring on Google or whatever. They will have a lot of what you need
Yes anything is possible with enough time money and skill.
If you are doing a 3.5 it would be a first I have seen as most people have no interest in this combo. Now if it is a 5.3 you are doing there are a few V8 conversions here. I am not aware of any direct bolt in kits but you can search for the treads to see what they have done.
Super Moderator
Well my dyslexia must have kicked in because I totally read 5.3, lol
To answer the OP's question I think it depends on the year of the 3.7L truck... I believe a 2007 truck can swap in a 3.5l relatively easy but a 2008 - 2012 has a different reluctor wheel, sensors, pcm plus a separate TCM ect...
Gee, I've seen hemi's in Volkswagen Beetles, various small block V-8's in Corvairs, motorcycles and even a snowblower, and helicopter jet engines in tractors so yes, I'm pretty sure your swap is possible. Probably not nearly as difficult as any of those I mentioned either.
You haven't lived til you've seen the reaction of a Ford guy to an LS-swapped Mustang :)
1 - 8 of 8 Posts
