Tried searching, but "map" is too short. Didn't really find any other posts on this subject, so here I am.
Has anyone removed and cleaned their MAP (not MAF) sensor and cleaned it or found it to be particularly gross? I know some folks like to pull and clean the EGR tube, but I don't recall seeing any mention about cleaning the MAP. I did this with my wife's EcoDiesel tonight because it's super easy to get to and clean. See attached pic for before/after results, Jeep has 60k on it.
Both my wife and I noticed that acceleration was a bit...non-linear. There would be a little bit of lag and then a sudden rush of boost when starting from a stop. Being a turbo diesel, some initial turbo lag is expected but this was more than typical based on the other diesels I've owned. Anyway, long story short, cleaning the MAP sensor solved the issue with excessive lag and sudden boost, there's better throttle response, better acceleration, and less lag now.
So, curious if anyone has done this with the LWN and what the results were in terms of dirtiness and/or performance/response changes after cleaning.
