So I've blown through 3 shock mounts in the past 2 years. The first time was my fault after installing my Bilstein 6112s, I didn't use the shock boot so I didn't have the bottom washer. Shock blew through the top, whatever next time I'll add a washer. I thought that was the fix for about a year until my shock pulled out of the mount because of droop and heavy 35" tires. This time both sides pulled out. My permanent solution is to install limit straps, everything should arrive next week. Here's my other solution, just for ease of mind mostly, not having to worry if my shock will rip out again when I'm on the trail. Came out feeling solid.
