1 - 2 of 2 Posts
The passenger rear exterior door handle on my 2016 LT has about a half inch of side-to-side play. I checked the others and while they all have some movement, none move as much as this one. Is there any way to easily tighten it up without a trip to the dealer to have the interior door panel removed?
If you look in the door jam even with the handle you should see a round black plastic peice thar can be removed. Pull it and you will be able to tighten a torx bolt down inside there
That should get rid of the play.
I hope that helps.
1 - 2 of 2 Posts
