1 - 8 of 8 Posts
I'm getting my BDS lift installed right now and the lift needs a max 4.5" backspacing for a 17" wheel but my fifteen52s are 4.75, so I've got a 3/8" spacer that puts it at 4.375, just enough clearance plus a tiny cushion. So I got a call from the shop today that my wheel studs aren't long enough for my aftermarket wheels with the 3/8" spacers and they need an extra half inch. I went into a bit of a panic since I can't order them and wait a few days, I need them now since the shop has the truck today and tomorrow.
So I spent day scouring the local auto parts stores and came up with a solution. It turns out that the 2016 Ford F-250 uses wheel studs with essentially the same same specs as ours, just .6 in longer. So if you're looking for just a little bit longer studs then you should be able to easily find those at a local auto parts store off the shelf.
I know Dorman doesn't make them for the factory but you'll find them as an OE replacement brand at many auto parts stores:
'16 Chevy Colorado stud specs:
Part #: Dorman 610-434
Head Diameter: 0.82 in. (20.83 mm)
Knurl Diameter: 0.63 in. (16.02 mm)
Shoulder Length: 0.688 in. (17.48 mm)
Thread Size: M14-1.5
Under Head Length: 2.281 In. (57.94 mm)
Thread Length: 1.08 in. (27.43 mm)
'16 Ford F-250 stud specs:
Part #: Dorman 610-509
Head Diameter: 0.79 in. (20.15 mm)
Knurl Diameter: 0.627 in (15.93 mm)
Shoulder Length: 0.675 in (17.15 mm)
Under Head Length: 2.89 in (73.4 mm)
Thread Length: 1.79 in (45.4 mm)
Sent from my Pixel 3a using Tapatalk
@FL8Z71 did that with those spacers, not sure which studs he went with though....
midnight, the threads on those do not look any longer????
Super Moderator
Actually after finding out those studs are around $8/ea. I decided to just buy 1" wheel spacers with studs built in. Eventually I'll get a wheel with a +00 offset and ditch the spacers but it's working for now.
Reactions: Hunter62
It's hard to tell in the photo but the top 1/2 of the threads are ground smooth like the longer stud.
The original specs for the Dorman wheel stud PN# 610-434 at about $3 each with an underhead length of 2.2806. While the longer stud PN# 610-428 at $2 each has an underhead length of 2.5748.
Discussion Starter #6
I think that's the concern. The underhead stud length is longer but the thread length is close to the same, just barely longer (27mm vs 31mm). So even though it's a longer stud it doesn't really give you many more threads for the lug nuts to grab.
Reactions: MidnightZ71
I see what you're saying. I guess in my application I only used a 3/8" spacer so the little 1/2 of threads is all I needed. I wish I would have gotten a better photo of them but wasn't expecting to post it online. I tried drawing on the photo to help a bit but I guess if someone is thinking about longer studs they can just pull both parts at the part store and compare. I was looking at ARP at first but 10$ a stud was more than I paid for the spacers :)
388657
Discussion Starter #8
Ouch. The f250 studs, which give as half in more threads, are ~$5 /ea from the auto parts stores.
1 - 8 of 8 Posts
