LED Fitment SOLVED in 15 Minutes w/ Pictures!!!
(Keep Reading... Entire Post Edited w/ Pictures)
I converted my 2017 Colorado Z71 to LED's.
I had 9005's in my 2016 Malibu and they will serve me well in the new Colorado.
They are Auto-Feel w/out an annoying fan. They are 6500k and 8000 lumens each. They basically turn night into day(people in the neighborhood love me).
Anyway, these types have a mushroom heat sink and that I can turn around as well for a better fitment on the low beams. High beams needed no such action.
They did not fit under the dust covers on the low beams due to the wire from the back. I needed just another 1/8" of clearance. Everything else fit in the housings.I was just a little, FREAKING ANNOYED at that point cuz of this fact so I reinstalled the halogens(except for the fog lights). Then I started going to hardware stores and other places looking for a solution. I did not want to comletely cut-away the the top of the cover or go for lower powered LED's.
While walking through the Wal-Mart motor oil ailse, it dawned on me that since I only needed that little 1/8", I could use a motor oil cap or better yet the caps off some of my washer fluid bottles(they're foil sealed anyway).
The cut-out on the dust cap isn't perfectly round, the RTV isn't the best looking caulking job, and the caps are still white, but I'll never see it anyway. Plus the washer fluid bottle caps give me another 5/8" clearance.
I hope this will help other who aren't interested in settling for just 4000 lumens so they don't have to modify their dust caps. This whole process took me only 15 minutes and I let the RTV cure over night.
Picture #1 Tools
Dremel
Washer Fluid Caps
Trim Tool or Screw Driver
Adhesive(I used Owens-Corning 732 RTV, Green Tube)
Dust Covers
Picture #2
Auto-Feel LED Headlight Assembly
Picture #3
Normal Heat Sink Position
Picture #4
Inverted Heat Sink Position
Picture #5
Dust Cap Cut-Out
Picture #6
The Uncapped Headlight Housing
Picture #7
Finished Dust Cap
Picture #8
Dust Cap Installed
Picture #1 Tools
Dremel
Washer Fluid Caps
Dust Covers
Picture #2
Picture #3
Picture #4
Picture #5
Dust Cap Cut-Out
Picture #6
Picture #7
Finished Dust Cap
Picture #8
Dust Cap Installed
