1 - 4 of 4 Posts
So for the Kinetik power cells, do you just run like a 1/0 gauge power cable from the car battery to the Kinetik and then you run your amps and stuff from that. And could you straighten me out on what it actually is, does it just store the power and then it uses that power to run the amps instead of havin the car battery and alt. takin the harshness of the system?
Thanks
it acts just like a secondary battery. I have dual runs of 1\0 to the kinetic in the rear with a negative run to the cab in the back. Then from there i have my amp hooked up. Its pretty much the same process as if you were running a capacitor but instead its a battery. It works hand in hand with your factory electrical system to keep up to the power needs of your equipment.
1 - 4 of 4 Posts
