I believe that is a cab mount. Probably didn't do any harm. But be sure and use a frame point next time.
Lifting on pinch welds is usually for unibody vehicles. If I have a frame, I would always lift there.GM wants us to use the pinch welds under the cab and cargo box. I like using the rear axle as a lifting point instead and the pinch weld for the front wheels when using a 3 ton or larger floor jack. To protect the pinch welds, I purchased a couple of black hockey puck like protectors that come with slots for the pinch welds. I also have something like the item below. Do a search on Amazon and you will come up with all kinds. I will not use a floor jack without one if the cup is large enough for a protector. The GM jack is unable to use a pinch weld protector. Many vehicles use the pinch weld for jacking up a vehicle. Long gone are the days of bumper jacks and railroad jacks for lifting vehicles.
NO. They want us to lift on the frame lift points as stated in the manual. Lifting on pinch welds is for unibody cars like Ridgelines haha.GM wants us to use the pinch welds under the cab and cargo box. I like using the rear axle as a lifting point instead and the pinch weld for the front wheels when using a 3 ton or larger floor jack. To protect the pinch welds, I purchased a couple of black hockey puck like protectors that come with slots for the pinch welds. I also have something like the item below. Do a search on Amazon and you will come up with all kinds. I will not use a floor jack without one if the cup is large enough for a protector. The GM jack is unable to use a pinch weld protector. Many vehicles use the pinch weld for jacking up a vehicle. Long gone are the days of bumper jacks and railroad jacks for lifting vehicles.
Hey, you got a creeper? I toss a old moving blanket on the ground and crawl.Makes me wonder where I went wrong.......
How does this guy have a rotary lift and I’m rolling on a creeper? Lmao
Ooops!!! :roll: I stand corrected as I was thinking about my Equinox that I rotated tires on last month. That only has pinch welds for lifting points. Yes there is an indentation in the frame for the front tires on my Colorado. The cup on my 3 ton jack was too big for the indentation so I used my hard rubber hockey puck like insert in the cup. Cannot stress enough to chock a wheel to two and not the one you are removing of course. I have a couple of scrap boards in my tool box for chocking a wheel or for putting the jack on if the ground is soft.NO. They want us to lift on the frame lift points as stated in the manual. Lifting on pinch welds is for unibody cars like Ridgelines haha.
But seriously, the cab pinch welds are not designed to lift the entire structure of a body on frame truck. You are however correct that we cannot lift from the bumper of this truck.
OP, you lifted from what I believe, as stated by others, is a cab mount. Should be fine, but I wouldn’t make a habit of it.
