This may help.
This was the diagram that I followed first, but I still had rapid blinking issuesThis may help. View attachment 416252
Thanks! I'll try this out when I get back home. I did notice during my testing that the resistors were not warm or hot at all. Probably an indicator of something, not sure what though.Also if you had the resistors on tails and tails on for a bit while trying to figure this out then the resistors might be toast. They will get hot quick under constant power. They get hot enough to melt plastic light housing just being used on turns that flash. Best to try and mount them to the bed so they can dissapate heat better.
Sit, Ubu, sit.
Those look pretty slick. Great selection on Amazon.I hate those crap/clip taps...these are from a site where I get all my motorcycle lighting...much better (IMO).
Posi-Tap Connectors
Posi-Tap Connectors allow you to tap into hot leads without cutting or stripping them. Shop all posi tap connectors and posi-products at Custom Dynamics.www.customdynamics.com
