1 - 16 of 16 Posts
I have seen reference to a few folks installing this to improve chassis stiffness especially related to the active jounce stops. No photos though and no mention of whether it works on non-ZR2. Yes it does, just not Diesels.
Because my airbags are slightly off center (outboard) from the frame and leaf spring centerline, figured it would be a good idea to add torsional stiffness to the frame rails to help counteract that.
We travel right at max GVWR when towing and camping so "it can't hurt" other than adding 15 lbs.
Hood Automotive design Automotive exterior Vehicle Bumper
White Automotive tire Motor vehicle Light Grille
I did a DIY weld in when I did the 589 shock relocation. Seemed to make the truck feel firmer.
Reactions: White016
man is that bar expensive... hows the ride now anyway? and why does it look like your shock is upside down?
Reactions: White016
Discussion Starter · #5 ·
Not really something that is noticeable as far as ride. Shock is upside down 'cause it is not a ZR2.
If you have a hitch, that should be good support.
Reactions: White016
mine isnt like that though.... and i dont have a zr2 either
Great, so know you're 15 lbs. over.
You are living on the edge!
:D
I used 1.75" cm tube, about $40 cost in all. Mine is about 8" further to the rear vs the gmpp $600 bar. There's a hole in the frame that was the perfect size and location, cut, mig, done.
Reactions: C21964 and White016
What!?!
That bar is $600??!
Discussion Starter · #12 · (Edited)
Yep that sounds great. I donated my MIG, TIG, and plasma cutter to the local high school when we moved to Texas. Once we get the new place finished will rebuild my shop and have capability to do that again. Right now ordering something bolt on online and installing it is a whole lot easier than tracking down a welding shop or fabricator willing to do the small jobs like that.
Nothing from GM Performance is cheap, heck even a plastic license plate frame for a Corvette is $80 ! Despite the prices there are apparently quite a few folks going all in on the complete ZR2 GMPerformance suspension and driveline upgrades. Plus you get a nice emblem with every order.
Being a clamp on mount, I just do not see it adding much rigidity, as it would if bolt on or weld on.
Price the jounce system - it retails for over $1700! If we could find the maker, we 'might' be able to get them cheaper, or wait for some aftermarket equivalent.
Discussion Starter · #16 · (Edited)
So I actually have noticed an apparent improvement. There is an intersection near our home where they have some pavement torn up, and making a hard right around the pylons and over some potholes, I could hear a slight "thumping noise" not too bad but there even with nothing in the bed. I thought it might have been the Bedslide. Well, after driving through it several times with no noise now, I think it was the bed cross rail where it rests on the frame, which is coincidentally right next to the new crossbar. Of course I can't be 100% certain but seems plausible there is now less frame flex relative to the bed.
1 - 16 of 16 Posts
