I believe the rears are a direct fit with a 1" block in the back.On the bright side, they aren't supposed to wear out like regular shocks. The bummer is I dont think I can just slap a set on my Z71 2wd, either. Not a chance at those prices, but it would be nice if they did actually fit and function properly.
5100s are my plan as well. I knew that ZR2 shocks would be expensive, but not that much.....ughWell, I wanted them until I saw the price. Ouch. Hopefully the 5100s will make a decent enough difference.
Comparing these to Bilstein and Eibach shocks is pointless, they're a remote reservoir shock, and as such are going to be a lot more expensive and functional than a single tube. Compare it to an Icon, Fox, or King remote reservoir, and it starts to even out the price tag.
Maybe they work better? I watched a good comparison video between the Tacoma on Foxs and the ZR2. They said tv's Tacoma would bounce and skitter around, while the ZR2 just soaked it up and stayed straight over all the rough stuff. You can even see the difference in the video. Where the ZR2 glides right through in a straight line, the Tacoma was all over the place.This exactly. Idk why someone would even want to get buy DSSVs when kings are a little cheaper.
The same level of shock from King or Fox is at the same price point, or higher. IMHO the DSSV is the superior shock based on my assometer and riding in rigs with high end Fox shocks.This exactly. Idk why someone would even want to get buy DSSVs when kings are a little cheaper.
I hope they do. I would consider picking up the cast-off DSSVs for the rear of my truck. From what I can see, should be an easy upgrade for regular twins.It'd be sweet to see someone put kings on a ZR2 and compare it to a stock ZR2 side by side.
