No, if you set the front to 2inch and the back to 1 inch you will still have a slight rake
I was gonna run the eibach kit at 3 inches since I have upper control arms and a bumber eventuallyNo, if you set the front to 2inch and the back to 1 inch you will still have a slight rake
I have a extended cab v6You did not say that when you asked the question
get a level, put it on the bed of you truck and with a little math you should be able to figure how much rake you have now and how much raising 3 inchs at the front wheel will negate the rake. have no idea which truck confuration you have,, extened cab, crew cab short bed, crew cab long bed it all makes a difference
