1 - 5 of 5 Posts
I am goingto 2in shackles with tb crank and was wondering how this would look.. Will I face any problems.. I want it to stick out little bit.
Probably 31in tire.
* 18x10 or (17x10 I think tires are cheaper)
* Bolt Pattern =6 on 5.5
* Back Spacing = 5.02 in.
* Offset = -12 mm.
* Hub Bore = 108
That sounds like its going to stick out A LOT!!! I went with a 4.25 backspacing on a 8 inch wide wheel with 11.50 tires and they stick out about an inch +/-
31 X 10.5 X 15 R
With the following rims.....
15 X 8
4.75" Backspacing
+6 MM Offset
6 X 5.5 Bolt Pattern
Thats what im running right now, and they stick out a bit.
If your getting into negative offsets, be prepared for mega protrusion.
10 inch wide rim i can imagine will be way to much, im on 33x12.50 on a 16x8 with a 4.5 inch backspace lemme see if i have a pic...
here we go..
my tires stick out a bit much, but im happy with it, im not sure how different urs will be being only a 10.50, but i think it will be way to wide of a rim
Gee, you're only what - 2 inches out there?
Gotta be tough to keep clean!
1 - 5 of 5 Posts
