141 - 157 of 157 Posts
just had a thought, could you cross the wiring behind the switch to make the so that when the DRLs powers on it will go to the relay for the running lights, cause it was kinda hard for me to follow those instructions so i was trying to find a easier way
Discussion Starter #143
Unfortunately no. All of the switches in the truck are 5v Data-Bus 2. Not standard 12v wiring.
Which part did you get lost on?
it wasnt really this one i got lost in i got that part mixed up i have an 07 so the lows are the drls it was the conversion to marker drls i got lost on,
all the wires that you would cross would be inside any, in the picture couldnt you switch the wires going out to the relay
Discussion Starter #145
The wiring isn't at the switch. The switch merely acts as a ;low voltage control. The Body Control Module (BCM) is the computer that handles what circuits to activate the full 12v to.
If your confusion is with the headlight/DRL conversion, you should ask your question in that thread.
I know this topic has been gone over again and again, but im just lost reading all these different posts. I have an 04 Colorado and want to do this. I plan on using stock amber bulbs. What exactly should i do? And if i change my mind and want to go with LED? Thanks and sorry for the repeat.
Discussion Starter #148
To run the stock bulbs, follow the original instructions and add a relay as per these instructions: viewtopic.php?f=6&t=51686&start=100
To run LED bulbs, you may not need to do anything else. If the turn signal flashes fast, then you will need to add a load equalizing resistor on each side of the truck. The resistor will bridge between the 12v+ and 12v- wires of the turn signal circuit.
Nice idea,nice job! May be you can help point me in the right direction.I've already done the DRL switch to parking lights.But with new rules in Nova Scotia everyone has to have DRLs.So I whanna keep my head light covers on,so how do I make my fogs come on to? Please help
Jus did this mod yesterday minus the relay. I haven't noticed any flickering from the reflections of my signals yet so I'm jus gona run em for now.
Yup noticed it now. good thing you guys do these write ups! :mrgreen:
I'm definately gonna have to do this modification to my truck...it looks pretty cool :)
i have an 07. is there anyway to switch my drl from my headlights to do this or does it have to stay on the head lamps? cuz there is no third wire for DRLs. it just sends a lower voltage to my low beams
About this Discussion
47 Participants
pissonford07
Chevy Colorado & GMC Canyon
Full Forum Listing
