121 - 140 of 157 Posts
Got em, thanks! Now just for the relays.
thats freaking sweet!!! ever thought of doing something like that with the rear lights?
does the dual drl mod need to be done to my 05??
DB, you need to work out how to delay your brake lights till the light bars reach them. :idea:
What socket does the 07 take, because the one listed does not fit,
The 3157 socket itself does not fit into the inside nor the out side sockets
85881 this socket does not work on my truck. (front lights)
well crap, here I go again, it's a tight fit that socket is huge comaired to the factory one, it can barely turn. I know the two factory sockets are different. here goes round two :lol:
also the bulbs are different inside is 3157 outside is 3757 I think, they do not interchange with each other.
Had same problem but a bit of shaving of the problem tab works.
After all its Autozone and supplier quality control wont be that tight.
Adapt, overcome, yada yada...........
Well I shaved off a tab on the factory sockets that I had and I now have DRL's in the inner bulb, I just ran a wire off the cut relay
Im sure this has been discussed but i cant find it, my truck has low voltage low beam DRLs can it be changed to the corner lights or any other options
If I may... I'll add some details of my successful attempt of this mod.
I used the AutoZone sockets and, 3157 Stealth bulbs from zetaproducts.net
I had to clip and file off the (2) small tabs on each bulb so they would fit in the sockets.
Use your thumbnails to push the bulb in so it makes contact. Check this if a bulb doesn't light up.
I also had to cut off part of the largest tab on the sockets so they would fit in the lamp housings and twist.
The wires on the AZ sockets are all black. The one marked 'A' is ground and goes to the black wire of the stock sockets.
The (2) small metal contacts in the sockets are ground. The larger contacts are park and turn.
I wired the new socket to the corresponding stock outer socket wires, then turned on the power to check.
Hmmm. The end filament on one bulb and the lower filament on the other lit up. Not sure why, but I just swapped the connections so the end (smaller, dimmer) filaments on both bulbs lit when on park and the lower (larger, brighter) filaments lit on turn.
The sequencer is ordered and i will update if needed, but don't expect it.
Been wanting to do this since I got the truck and can't feature why Government Motors didn't do it originally. :roll:
umm..
