Snapping an axle is more a result of reckless driving vs tire size. Sure, tire size contributes, but you can blow an axle on stock tires if you "just send it". Meanwhile a careful driver on 37's could last a lifetime.
You can put the largest tires you can fit without a lift and probably be fine. You'll be lucky if you can stuff 33s.I have a 2012 Chevy Colorado and want to know how big of tires I can put on before I start snapping axles and I do off-roading I have the z71 package with the i5
So like 35 at the most I do like full on Rock crawling in Moab so from flex and just bumping it up brocks and doing up rocks I have had buddy’s snap axlesSnapping an axle is more a result of reckless driving vs tire size. Sure, tire size contributes, but you can blow an axle on stock tires if you "just send it". Meanwhile a careful driver on 37's could last a lifetime.
Sorry that makes no sense what I just said bumping it up rocks and my buddys snap them from spinning out going up rocksSo like 35 at the most I do like full on Rock crawling in Moab so from flex and just bumping it up brocks and doing up rocks I have had buddy’s snap axles
This is my argument against the G80 locker. Great idea but is based on a spinning wheel that suddenly locks up.And yes, ANY sort of wheel spin with sudden traction will break things.
then why ask us if your buddies are breaking axles?So like 35 at the most I do like full on Rock crawling in Moab so from flex and just bumping it up brocks and doing up rocks I have had buddy’s snap axles
he has a first gen truck37's have destroyed rear diffs in the past. Larger wheels/tires add weight and more wear and tear to the brake, suspension components and shocks.
I opted for 33's, it's fairly easy and cheap. 35's or larger gets spendy and unless you live to crawl you don't see that big of benefit.
