I have a 2005 Chevy Colorado with the 3.5 liter straight 5 engine and auto tranny.
I have been experiencing a few oddities lately with the cruise control. It would randomly stop working and then start working again. I replaced the brake light stop switch by the brake pedal (part 5 on the GM diagram). It was a $10 fix and I had to try that first. I have not replaced the cruise control stop switch (part 6). I thought the popular stop switch failure would fix things but it hasn't.
The cruise control stopped again going down the highway for no reason. I came to a stop, pushed an umbrella against the brake and the seat and checked to make sure that all the rear brake lights were working, and they were. When I drove a bit more, I noticed that while I was manually driving, the engine RPM was up about 500 RPM. The engine consistently sounded like it was running in 3rd gear. It would not go into 4th, even on the flat or downhill. The tranny did shift in between 1st and 3rd gears, but the 4th gear would not engage. It was at roughly 2800 RPM at 75 MPH...something that would normally be around say 2200 or 2300 RPM. After foot driving for about half an hour, the cruise worked again and magically the tranny up-shifted and the RPM dropped.
Over the past year, I have had a few tranny anomalies aside from this.Once I was at a stop light and when I got the green, I went to hit the gas and all that happened was the RPM revved up (no gear grinding, just non-engagement). I shifted into neutral and back and problem fixed. The same problem seems to have happened when the tranny should have shifted in between 2nd and 3rd or 3rd and 4th before as well. The problems are rare and happen when you least expect it. One thing is for sure now though. I can't go on a trip out of town anymore without this stupid cruise control and transmission problem. I have no lights on the dash by the way, although I have not chec3ked for error codes.
There's a lot of knowledge on this forum. Anybody else ever run into this? Am I screwed? I assume that part 6 for the cruise control by the break pedal doesn't affect the tranny, it is the other way around, right? Any thoughts? I still like my Colorado and just put a new front bumper and LED light bar on it...but these expensive repairs just keep on coming. Please and thank you.
