1 - 6 of 6 Posts
Tap into the fuse box for the positive wire and use the radio ground for the negative. If you have a lot of stereo equipment you may want to find another ground because it might cause some background noise. Don't use the wires for the dome light because the truck knows when there is power going throught the wires and when the TV is on all of the interior lights will come on and stay on until the TV is turned off. I tried to connect to the ground wire in my truck and that is what happened.
As far as airbags, you should only have to worry if you have side curtain airbags when you are runnning the wires through the A pillars. Other than that I don't think the airbags will be a factor.
1 - 6 of 6 Posts
