I have a 2016 Colorado Z71 4wd just put a 6” suspension lift on. And ordered some 20x12 -44 with 33x12.5, I’m concerned if the factory cv shafts are enough, or should I put heavy duty one’s on
-44 off-set? the oem wheels are 33 off-set plus a 5 inch wider wheel so that will push the wheel/tire out more then 5 inches. Will need to do some fender trimming. With that much weight and torque on the end of the axles I would say yes.
