1 - 11 of 11 Posts
hey guys just wondering if anyone has any advice on HID's or projector bulbs,. Tried searching for a while tonight, couldnt find much though. If anyone has advice on brand, price, where to buy etc. I would greatly value that info! Also If I have 2 amplifiers totaling 1000 watts, will a kit cause them to dim? also any type of install conflicts would be great!
HIDs are sweet, I have them in 8000K which is kinda blueish. 6000K is a little more white/legal looking haha.
The kit depends on how much you want to spend, the better ones are Pilot, MTec, McCulloch in my opinion. They will run you about 200 for a set, eBay is usually the best place to look I suppose. As far as your amps ago, the HIDs really shouldnt dim because they draw power from their own ballast/power source..then again I dont know 100%
Projector lights are really cool, but I've heard fitting real HID bulbs in them is a son of a gun.
Anyway, hope this helps
Yeah man it sure does!! So were yours hard to install or what? Saw your cardomain BTW sweet truck man!
So I have to take out the stock assembly completely?? And do I have to do any splicing, or will It just be clipping stuff on to stock harnesses??
Sweet So obviously there is a specific kit for our trucks right? I'm assuming an ebay search for "Colorado Pilot HIDS" should pull something?
Discussion Starter #9
Oh so HIDS retain the stock headlight housing, and it is a matter of replacing the bulbs and running a standalone power source to it??
Discussion Starter #10
Hey also how do you like your prosx?? How does it sound? and did it just bult up on place of stock, or was welding required?
Yes, the HIDs should come with everything you need :wink:
I really like my ProXs, here is a clip. The video does not do it justice, it sounds much better in person and once it has broken in a little bit. It must be welded, but you can have an exhaust shop swap mufflers and retain stock piping
http://smg.photobucket.com/albums/v427/ ... xhaust.flv
1 - 11 of 11 Posts
