Has anyone done 2” strut spacer and 1” lift blocks?
1216 Views 4 Replies 5 Participants Last post by  Speedy4x4
Has anyone on here done the 2” strut spacer in the front and put in a 1” lift block in the rear? Just wondering what it would look like before I order the blocks! The truck looks level with the 2” up front but now with a small gap in the rear wheel well it looks squatted a bit.
1 - 5 of 5 Posts
I did 2.5 strut spacer and 1" rear blocks. Looks great with just a slight rake. However, if you tow heavy trailers, you'll want to go back to stock rake, so figure 2" blocks in the rear. When I hooked up to my travel trailer after the lift, the rear squatted lower than the front. Also creates a safety issue by shifting weight off of the front tires while towing. I'll be going to a two inch rear block at some point.
See less See more
Reactions: 1
same here 2.5/1 i think its perfect, small rake.
I just ordered a 2" front and 1.5 rear to go with my new wheel and tire combo, my bed is hardly ever empty, but I also like some rake.
1 - 5 of 5 Posts
