1 - 7 of 7 Posts
2017 gmc canyon 2wd 4cyl. I have a rattle that usually happens only around 1500rpm when accelerating or keeping foot on the gas coasting. Does not happen in neutral or if I take my foot off the gas. If I continue to accelerate past 1500rpm or take my foot off the gas it goes away. It’s also intermittent and happens only 80% of the time for the past couple months. Has 20k miles.
in the video you can hear it go away at 46mph (11 seconds) once I begin to accelerate..
help! It’s bugging the **** out of me and I’ve looked around and doesn’t appear to be heat shield or anything else that’s loose that I’ve seen.
video here
put it in tow mode and see if it does it
did you buy it new?
have you had the transmission fluid changed?
Sorry.. should have mentioned. It’s 2wd 4 cylinder so no tow mode. Bought used at 16k and have not had trans fluid changed. Changed oil a few weeks ago.
okay, then forget about my post, you have the 6 speed transmission, the 8-speed has what they call the shudder
I heard the noise in your video, check catylytic converter area, beat on things, may be a selenoid//
Discussion Starter · #6 ·
Thanks. I’ve checked my ecm mount and seems secure. I’ll give it another look as well as the area under steering column.
Discussion Starter · #7 ·
Bump. Probably going to take it in to get diagnosed but anyone got any last suggestions before I do? Would love to not have to…
hasnt been any of the above and looked all around in the engine compartment/fenders/under carriage and nothing seems loose..
Thanks
1 - 7 of 7 Posts
