Program Title:
HVAC Module Temp Door
Program Description:
Certain 2015-2016 model year Chevrolet Colorado and 2015-2016 model year GMC Canyon vehicles, may have a condition in which a crack in the heating and cooling module temperature door control shaft may form and result in inconsistent air discharge temperature control. If the shaft cracks, the air discharge temperature may be up to 33 degrees Fahrenheit (20 degrees Celsius) cooler than the requested values, depending on the HVAC mode selected.
Safety Risk Description:
The air discharge temperature may be up to 33 degrees Fahrenheit (20 degrees Celsius) cooler than the requested values, depending on the HVAC mode selected.
Repair Description:
Inspect the temperature valve control shaft for cracks. If the shaft is intact, install a reinforcing clamp around the temperature valve shaft to prevent the shaft from cracking. If more than one crack is present, replace the temperature control valve.
Customer Action:
Contact your dealer as soon as possible to schedule an appointment for this repair. By scheduling an appointment, your dealer can ensure that the necessary parts will be available on your scheduled appointment date.
Repair Description:
Customer Action:
