1 - 7 of 7 Posts
Fuel pressure tester is a loaner tool at most auto parts stores. I usually pay the deposit and check mine right there in the parking lot. I'd google to see what the pressure is supposed to be. Usually you'll see instructions for a standard pressure test and one for a leak down test. What are the symptoms? If I suspect a fuel pump problem, I usually replace the filter before testing the pump.
Discussion Starter · #5 ·
First start of the day always takes longer to fire replaced the fuel pressure regulator but made no difference will try a filter next
1 - 7 of 7 Posts
