Help ! Does anyone know where I can purchase the lower spring mounts for the front shocks? I am trying to put together a complete coil over shock assembly so I can swap out shocks without any delays.
it is removable , but I would like to have them ready to go when I change them out. But doesn't look like they are available. So I may have to deal with it as I go.
so you just want new shocks? I don't get it. You buy shocks then install them. Like that. Or do you need an extra set, spring and all? I bet you could get the whole assembly if you want, more money but no spring compressor needed. I guess I don't know why you want a new perch????it is removable , but I would like to have them ready to go when I change them out. But doesn't look like they are available. So I may have to deal with it as I go.
Me either, the only thing it would save is the spring compressor, which where I live is loaned by Oreillys/Autozone for free.so you just want new shocks? I don't get it. You buy shocks then install them. Like that. Or do you need an extra set, spring and all? I bet you could get the whole assembly if you want, more money but no spring compressor needed. I guess I don't know why you want a new perch????
Because Eibach has a new coil springs to go with their RHA shocks, that require using the factory top and bottom mount hardware. The springs give a 2" lift with the lowest mount setting. They state the use of their strut/shock only with their spring.so you just want new shocks? I don't get it. You buy shocks then install them. Like that. Or do you need an extra set, spring and all? I bet you could get the whole assembly if you want, more money but no spring compressor needed. I guess I don't know why you want a new perch????
Been kinda poking around that same path also. The top mount parts are also needed, which are around $120 add, so not in a hurry...
Well, if they require the original mount hardware it's right there on the truck now.....As for them wanting you to use their springs, I'm sure its because the their shocks are longer/taller. Right??Because Eibach has a new coil springs to go with their RHA shocks, that require using the factory top and bottom mount hardware. The springs give a 2" lift with the lowest mount setting. They state the use of their strut/shock only with their spring.
Yes, but spring rate is not listed. They also advise not going past the 2nd (.7) setting.So those coil springs sold by Eibach are 2" longer than the OEM coils? Do they have a higher spring rate than OEM? If the Eibach coils are 2" longer than stock by themselves I guess you can get more than 2" of lift if you use their RHA shocks?
It's a system, so I'm sure they wouldn't recommend otherwise.Well, if they require the original mount hardware it's right there on the truck now.....As for them wanting you to use their springs, I'm sure its because the their shocks
