1 - 11 of 11 Posts
There are two 1-13/16" holes in the frame of my SLT, one on each side, just behind the rear axle housing, partially covered by the wheel housing liner. These are thru holes extruded to the inside of the boxed frame. Is there a purpose for these holes, ie. crush area or previous suspension use etc.?
Howard
Really not sure why they are there. Do you have use for them or just wandering? There has to be a reason, for them to go to the trouble of putting them there, unless they are lifting points on the assembly line.
I was thinking of using them for mud flap hanger mounts. I'm going to put a set of 12 x 18" flaps on the rear. Factory flaps are useless and weather tech don't look any better. (They don't hang low enough). I live on back roads and the dirt and crap is getting thrown back into the bumper.
The holes are there to make people ask questions why they are there.
The holes in the frames can be for many reasons From transportation, crash or MFG. Either way you should be safe using them for the flaps if you choose. Many aftermarket parts use use existing holes and mounts for putting on hitches, steps and bars.
Could also be there for strapping points for transit from the frame plant to assembly plant. If you have use for them, by all means do so, or they will never get used again.
Discussion Starter #8
Thanks to all. I'll probably get to the fabrication in a few days. I'll know then if I can make the existing holes work. I'd rather not drill additional holes if I don't have to. My last truck, (2001, 2500HD, Duramax)' had a substantial channel frame that I felt more comfortable drilling and bolting to. We'll see.
Thanks again,
Howard
Post some pics. when finished.
Discussion Starter #10
It might be a while. I did more measuring today and found the inner frame hole is a little bigger than the outer hole. No game changer if I decide they'll work for what I'm doing. Pictures are a problem for me but I can get the wife to take some.
Howard
Holes. .. ? There are many reasons for them in the frame. Mostly good places for us to use and attach mods and accessories!
1 - 11 of 11 Posts
