1 - 5 of 5 Posts
Driving down the road the other day... crusing between 55-60 the DIC starts flashing BRAKES on the screen and my ABS light as well as my emergency brake light were flashing at me... The brake was not set as I pulled over completely depressed the E brake pedal and then released it. Didn't clear the lights... I proceeded home turned the truck off and came back out latr to look at it again. I started the truck and everything was clear. Yesterday, the same thing happened. ANy clues as to what the heck is going on???
Check that your battery isn't dying.
In the winter, my ABS FAULT light comes on when its really cold, but other than that, it doesnt give me problems.
Wheel speed sensor. This has happened with quite a few trucks. I was driving down the interstate and the ABS fault light came on, looked at some threads on here, went to the dealership and told them to check the wheel speed sensor. Sure enough, front right was bad. I still haven't gotten it fixed, but every now and then my ABS fault light will come back on.
Hope this explains all the lights. if not, then I have no idea.
1 - 5 of 5 Posts
