Thank you. I am having fun myself. I like a clean install and everything I do takes time but in the end looks factory (almost....).What a great find, and excellent schematic, so thanks for sharing this.
I see your two 12v outlets there as well, so want to ask where you sourced the 12v for those and the switch. Also, how much current will that 12v source support?
Like Yooper, I'm waiting for my diesel to be built, and having fun planning the improvements.
The 12VDC source came from the 12VDC supply to the trailer wiring harness, which comes from the Trailer Module above the spare tire. The line is rated for 30A, but reality is that the 12VDC outlets I connected to a 15A fuse. My LED bed lights pull a whopping 1A so even thought it is a bit overkill, I have room for any growth and protection from shorts and stupidity.
I tapped off the ground at the Trailer wiring harness too (both connections are from behind the bumper), placed in split loom and sealed with GOOD 3M vinyl black tape (not that cheap Harbor Freight crapola). The 3M stuff is soooo good and seals so well. Worth the $5 a roll price. I ran the loom along the rest of the harnesses there until the left quarter panel, where I then followed the LR brake light harness. Everything zip tied for clean and secure install. Once i diverge from that harness and run up to the front of the stake pocket, I placed some loom over the entrance to the bed (picture attached) and used adhesive to hold it in place. The loom is double protected then, and this is where the wiring for the bed lights and 12VDC service outlets are connected to those items. The switch you can see in the diagram, and it runs in that pre cut hole into the stake pocket and then out the back of the stake pocket and down right behind the LR brake light harness and joins at the location of the GM connection for cargo lamps. Everything looks good and is sturdy. I am happy.
