So I'm Going to do the repair for code P0449 using the hummer H3 solenoid fix
This is like a normal issue on these trucks I read up the charcoal canister solenoid goes bad .
Watched a couple YouTube videos on the fix instead of spending $230 on colorado solenoid with the line attatched you can buy the H3 Hummer solenoid alone for $23 and it's the same part #
My question is I got the truck with th is issue does this normally pose a running issue or what does that solenoid affect if it's bad
