For a 2-3" lift:
When you install the lift:
- UCAs (I went with SPC)
- Extended sway links (I used Prothane 19419)
- Sway bar drop kit (Streetrays popular, mine came with my Kings)
- (I do not recommend this) Diff Drop kit (Peak, Eibach, whoever).
If you regear, you will lose cruise control due to an ABS wheel speed sensor mismatch. I'm not terribly familiar with the gas trucks and tuning, but it's possible Trifecta can adjust the gear ratio in the tune like you can on a diesel truck.
As for being capable offroad, you want several things out of your truck. This is in my order of importance:
- Ability to maneuver (Not overloading the truck like I imagine a lot of "overlanders" are). Don't go over GVWR regardless of what a suspension company has told you about increased payload. GAWR is the important metric behind GVWR and unless you axle swap, you can't improve GAWR.
- Ability to clear obstacles (increase your ground clearance to improve approach, departure, and breakover angles). You do this through a combination of tire size and lift. How you lift (pucks, body, or suspension) will determine what your wheel travel will be. I really believe you get what you pay for with lifting in terms of ride comfort and wheel travel.
- Ability to (self) recover (Winch, recovery points, shackles, traction boards, straps, snatch block, venerable hilift jack, etc...). The "RhinoUSA" recovery stuff listed is made in China but so is most of the Warn and ARB stuff now. Those RhinoUSA items appear to be ARB clones and have worked well for me on several occasions.
- Ability for the truck to survive driver mistakes (Skids, armor, steel bumpers. The skid support bracket is a known 2nd Gen weakpoint. 589fab fix)
- Ability to see (Lighting in all directions. Diode Dynamics, Baja, and Rigid all make great stuff. eBay and Amazon cheap lights will fail/fill with water/sunfade faster.)
- Ability to communicate with others on the trail (GMRS/FRS, CB, HAM, etc...). The Retevis radios I linked are cheap FRS radios with good range/durability and can be reprogrammed into GMRS radios once the proper licensing is obtained and you know how.
[*]Tie Rod Sleeves are a divisive topic because the tie rods could (probably) are designed to be the weak point in the system and putting gnarly sleeves on them shifts the point of failure to something else (could be the steering rack itself). I have sleeves (Merchant Automotive), I didn't consider this when I put them on, but I do like the way they look. I may take them off. There are also now "short sleeves" but I believe they will have the same effect. For an insta warrior, they look great. For rock crawling, they might cause bigger issues than tie rod replacement.
[*]Shock guards are good to go and "necessary" depending on your use case. For a serious offroader or insta warrior, probably worthwhile.
