Has anyone run the Eibach spring shock combo on a diesel? I've been reading that the diesel engine weights a bit heavier then the gasers. I'm about to pull the trigger on the combo, but I want to make sure that it will even the front out on my diesel Z71.
Also what if any size block in the rear would I need to run to to make the truck sit even.
Thanks for the help in advance.
Sent from my MHA-L29 using Tapatalk
