I see a lot of folks debadging their trucks, so I thought I'd share a way to do this with almost no effort.
Kano Labs makes a paint-safe degreaser called Floway, and this literally melts away the foam backing and adhesive. I won't say the letters quite fall off, but you can peel them off with your bare hand. Soak it down and let it sit for 15 minutes or so. Any remaining adhesive vanishes if you lightly rub it with a soft cloth sprayed with a bit more of the product. Obviously this also removes any wax, so clean and reapply after badge removal.
Definitely easier than heat guns, Simple Green, floss, and anything else I've tried over the years.
I'll also mention another great Kano product -- Kroil. It's an amazing penetrating oil. When I restored the suspension on my 55 Buick, there were many nuts and bolts that hadn't budged in over half a century. A tiny shot of Kroil and a few minutes later they came out as easily as if they were new. No exaggeration. A friend had given me a spray bottle of the stuff, they use it to disassemble salt-water-corroded ship fittings. When I ordered a gallon (which is a lifetime supply), Kano threw in a can of Floway for free.
No, I don't work for them.
https://smile.amazon.com/Kano-Floway-Engine-Cleaner-Aerosol/dp/B005XUIX9C?sa-no-redirect=1
https://smile.amazon.com/Kano-Aerokroil-Penetrating-aerosol-AEROKROIL/dp/B000F09CEA?sa-no-redirect=1
