This is for you first time DIY oil changers on V6. Drain plug warning. The drain plug in the oil pan is 90 degrees to the bottom of the pan. That is it is straight out the side of the pan. When you pull the plug, the oil will go right across the top of you ketch pan and land on to your wheel and lower a suspension and land on your nice concrete garage floor or driveway. Don't ask me how I know this. The reason I was changing my own oil is because after driving 1400 miles back to Florida this summer and sorting out my accumulated paperwork I discovered that the tire store that I allowed to change my oil installed 0-20 weight oil. That oil only goes in the 4 cyl and only in extreme cold climates. I've been told a check is in the mail. When I looked thru the waiting room window I wondered why there was oil all over the floor under my truck. I had a good laugh and didn't think too much about it. I changed the oil myself and now I know why I saw oil all over the floor. FYI.
