1 - 6 of 6 Posts
Can someone tell me the proper way to get to the lamp switch panel so I can replace the Dome override switch.
My switch doesn't stay in when pushed so I need to put in another switch.
I usually end up taking off way too many parts when I work on the dash.
Also I might be able to put in a switch and wiring for fog lamp switch at the same time.
Thanks
  1. Start by removing the screw from the side of the drivers side lower dash panel.
    [/*:m:2cl5cdjn]
  2. Using a trim too, gently pry the lower dash panel loose to revel the screw the holds the headlight switch in place. Remove the screw with a 7mm nut driver.
    [/*:m:2cl5cdjn]
  3. Using a trim tool, gently pry the drivers side vent loose and remove.
    [/*:m:2cl5cdjn]
  4. Removing the vent makes it much easier to access the back of the switch to release the electrical connector from the back to the switch.
    [/*:m:2cl5cdjn]
  5. Unplug the electrical connector from the back of the headlight switch.
    [/*:m:2cl5cdjn]
  6. Carefully remove the switch through the vent opening.
    [/*:m:2cl5cdjn]
  7. Take the switch to your work bench to disassemble the headlight switch.
    [/*:m:2cl5cdjn]
Go figure - I took it all apart - couldn't see anything wrong or broken - not that one can replace just the dome override switch, they only sell the whole unit) so I planned how to bridge the applicable wires outside the box with my own switch - but the switch unit back together, and found the switch now works :D
1 - 6 of 6 Posts
