1 - 20 of 25 Posts
Hey folks, for those who are running stock size tires 255/55R20 what kind of tire do you have on the truck? After a fair amount of research it seems, the tire manufactures do not offer many "truck" options in this size. Living in Michigan, we just got hit with about 10" of snow this week, and the O.E Bridgestones are not going to make it for the winter.
I have used the factory tires the last two winters. We are on the south east side of Lake Erie in the snow belt and so far the the Bridgestone's have not been an issue.
I was skeptical before I drove them but they worked fined. We had a number of deep snows and I have not had an issue getting around what so ever. I am just going to keep these on.
If and when they wear out I may keep the same or May go to the Goodyear Assurance Weather Ready tires. We just put them on the wife's vehicle as her OE Michelin's were toast by 20K miles. The reviews put the Weather Ready's at around 50K plus miles and good all weather traction.
I do not go off road much so I will keep with a more road tread than off road.
I was pretty surprised at the lack of decent tires available in that size. I picked up a set of wheels & tires someone pulled off an All Terrain for winter & trail duty. I'll swap during the winter months when we get muddy and run proper "summer" tires on the 20s during the dry months here.
I live on some back roads that don't get plowed to quick in the snowy months. The truck seems to break loose really easy with the diesel motor way too often, I decided to throw on a set of LTX Michelin tires. I alway had great luck with these back in the day when I had a 2wd Silverado 02.
Generally the AT tires are going to be for smaller wheels as you really don't want lower profile tires for off road. This is why the ZR2 has 17" as the side wall works better off road though on the road it may not be the best for handling.
The 20" tires are mostly targeted for the road since that is what most buy them for,
Discussion Starter #9
I check out the WildPeak A/T Trails, but they seem to be marketed for more SUV Crossover vehicles. Not to sure how they would hold up. Wound up getting the LTX's installed last Friday at Bell Tire. The back roads were still about 1" tick packed snow ice, I did a few test stops and starts and I couldn't believe the difference between the two. The Michelins are not the prettiest most aggressive looking tire, but the sure hook up on the snow and ice a hell of a lot better than the O.E Bridgestones.
I'm looking for new all terrain tires for Denali as well. There's lots of options at 275 width, but that's going to be too big for my setup. If you look at 265/50/20, theres 5 or more all terrain options. That's not a larger diameter than the 255/55 and should fit on ours.
I have a 2" level on the front, 1" block in the rear, and wheel spacers with the stock Denali wheels and tires. I get occasion rubbing on the mud guard, so I'm debating on what size to go with.
Michlen LTX Defender....best all around tire I have ever had.....good choice
Discussion Starter #12
Check out a 245/60/R20, I saw a Toyo Open Country A/T available in that size, I was worried they would rub with the additional height. I'm not running a lift on my truck so I passed on them, not to mention they are priced around $245.00 a tire. Good luck, maybe someday the tire manufactures will begin to produce an A/T in the stock size for the Denali crowd.
Just bit the bullet, Toyo Open Country AT2. 265/50/20. So slightly wider tread but overall diameter not larger than stock. A larger sidewall would have given me rubbing issues, so that’s why I kept close to original size.
Pirelli Scorpion A/T Plus- 265/60r18. Ran them on a Jeep Cherokee last winter and loved them, in our Wisconsin snows. 2019 Colorado- replaced the stock Good Year Wranglers at 7500 miles, those tires were trash, any wet surface they broke loose. If I drive conservatively, these tires even work in 2 wd.
That size isn’t for the Denali trucks, which is what this thread is for. I’m sure those are good tires but sometimes they’re not made in sizes for us or the tires for the larger 20” wheels don’t perform like they do for smaller wheels.
Reactions: KSMOCanyon
Discussion Starter #16
Those Toyo's look sharp on that truck! Nice choice, the side wall looks much more suitable on a pickup truck than the stock Bridgestones or even the LTX I put on my truck. How do you like the tires so far?
Any increase in road noise or change in perceived ride quality?
2020 Chevrolet Colorado Crew Cab Short Box LT
I do a lot of winter driving in less than favorable conditions to go back country skiing in the mountains. I ran all terrain tires for years on SUV's until I started driving an Avalanche 1500 4 X 4. I started running Cooper Discoverer M & S and was amazed at the wet and winter traction. These were the best snow tires I ever had in a lifetime of winter driving. The downside is I saw a slight decrease in gas mileage and the tires only last 30,000 to 35,000 miles.
When my Colorado stock tires get a few miles on them I may go back to the M & S or the higher rated Cooper Discoverer RTX. Cooper Tires
1 - 20 of 25 Posts
