I know there are a lot of posts about DEF, but this is a topic that I have not seen addressed.
2018 Colorado Diesel
224 miles
Stock (But not for long)
I was looking around the computer system with an OBD II reader and found that the system was reporting the DEF level at 45 percent. This, of course, should not be after only 224 miles. Thinking that the dealer did not fill the DEF tank before delivery, I took the truck into the dealer. The dealer tried to add DEF, and the tank immediately overflowed. Thus, we verified that the tank was physically full at, or above 100 percent. The dealer then connected his OBD II reader and got the same result; 45 percent full. He tried to refresh the data, and reset the sensor feed, but still the same reading. The dealer could not find any technical bulletins, or software upgrades. He is contacting GM for directions.
I will, of course, post an update when a solution is found, but I was wondering if anyone else had this sort of sensor problem. I have seen reports of "Low DEF" warnings that did not seem to make sense. Some of these may have been sensor issues like mine. In any case, it might be worth checking if you have an OBD II reader available.
224 miles
