1 - 16 of 16 Posts
Hi y'all,
I would like to introduce my new adventuring rig and myself. My truck is a 2016 Colorado Diesel Z71 4x4 that is currently sitting at 20k miles. I am located in the Pacific Northwest (PNW) and work as a software engineer. My wife is an athletic trainer and a teacher. We were both born and raised in Central Texas, then attended the University of Texas, and lastly moved to the greater Seattle area last year for work.
My rig is somewhat unique and is not a typical overlanding build as it is getting a full long travel suspension front and rear. The main purpose for my rig is for my wife and I to have fun. Whether that is to hit some trails and service roads in Pacific Northwest, take the truck and quads (Yamaha Raptor 700R and YFZ 450R) out to the sand dunes, camp/glamp, take a long road trip, find a nice remote viewpoint, drive up a pass to go ski/board, or go to an overland rally to learn and meet new people.
I am a huge go getter, will do all the work I can myself and like to do things only once (the right way). I am constantly going through forums trying to learn new things, meet/help others and just check out other cool builds. I plan on doing better a better job at documenting our travels in the truck, as I now have a gopro and camera to use. Also starting this thread should help as I have a place to keep everything updated.
I will admit that I don't have as much experience in the offroading/overlanding world as I would like to. I have come from another world, as my previous build was a 1990 300ZX with an LS3 swap, an ultimate street and track build (picture attached). However the new rig will be much better suited to having fun in the PNW and beyond. I look forward to gaining experience and learning as time goes on.
Following is a list of things purchased, things needed and things wanted. It will continue to change and grow as time goes on.
Purchased (some pieces not installed):
- Method Grids Black (6)
- Falken AT3W 35x12.5x17 (6)
- Baja Kits +2 Prerunner Kit this kit includes our boxed upper and lower arms, custom heat treated axles, grade 9 hardware kit, extended brake lines and steering extension
- Baja Kits Frame Side Bypass Mount
- Custom King 2.5 Coilovers
- Custom King 2.5 Bypass
- Baja Kits Spring Under Kit
- Deaver Springs
- Baja Kits Bump stop Kit
- King 2.5 Bump stops
- King 2.5 rear shock
- King 2 Tube Bypass
- Fiberwerx front and rear fenders with bumper caps
- All In Trucks Tune and dsp4 switch
- ProFab intake and intercooler pipes
- FloPro Aluminized Exhaust
- Leitner rack
- Leitner MaxTrax mount
- Leitner MaxTrax pins
- (2) MaxTrax pair grey
- (2) Leitner Rotopax mounting plate
- (3) Diesel 2 gal Rotopax
- Water 2 gal Rotopax
- (2) Rotopax extensions
- (2) Rotopax lock mount
- Leitner HiLift bracket
- HiLift Jack Extreme
- Leitner RTT mounts
- (4) Leitner light mounts (for bar or pods)
- Fire extinguisher
- Camp Chef 2 Burner Camp stove with bag and hose adapter
- 2 Gallon propane tank
- (4) Camping chairs
- Folding table
- Lighter
Future:
- Sliders
- Superskidz (all 5 pieces)
- Lights on lights on lights
- Roof rack
- Go pro mount on windshield
- Pressure down tool
- Bottle jack
- Offroad jack
- Winch
- Front and Rear bumpers
- Recovery kit
- Twin onboard compressor
- Dual battery setup
- SPOD or other similar
- Cooler/Fridge
- First aid kit
- Map/gps setup
- Radios
- Hard cases
- ? Water filtration system
- Grill
- AX and Shovel mount on rack inside?
- Inverter
- Outlets with inverter
- Solar panel setup
- Tool kit (so I dont have to take my tools from home)
- Lantern
- Flashlights
- Zippo
- Paracord
- Sleeping bags
- ? Fishing poles
Sounds like you have been focusing on the vehicle, with little thought on how to get our when you get stuck.
Consider these: https://us.maxtrax.com.au/
A land anchor, make sure you mount it securely, it is heavy enough to punch holes in things.
tree strap
Hi Lift jack - can also be used as a winch. Hi-Lift Jack Company - Highest quality equipment at a reasonable price get the 60" version; and take a close look at accessories. Make sure you mount it securely, it is heavy enough to punch holes in things.
tree strap
If you read what he wrote, he has maxtrax and a hilift extreme.
Reactions: maxwell_hau5_caffy
Super Moderator
+1 to Software Enginerd. I graduated with a B.S. in Comp Sci from UCF.
Anyways, seen your pics on fb and looking forward to seeing pics of your build when you get the prerunner kit on there.
EDIT: Also, I saw you were planning on getting some skids soon. Get those yesterday. I made the mistake of putting them off, and had more problems cause i had done some damage to the mounting points for the #1 and #2 skids. Hopefully you havent done the same yet.
Do the rears mount over the bed sides, or do you have to remove the metal bed sides and replace with those?
You have to drill out all the spot welds and remove both rear steel bedsides.. then bolt on 4 painted fiberglass fenders.
Looks like it will be a cool build, I gotta say you are crazy for running fiberglass fenders if you plan on going into the woods or gravel roads.
Great looking build! Looking forward to tracking the progress here.
How do you like the Leitner rack so far? Does it intrude considerably into the bed?
Sent from my BBB100-1 using Tapatalk
Discussion Starter #14
It is not too bad. Most intrusive part are the rear bars that go down right in front of the tailgate. They can get annoying.
Discussion Starter #16
Pics from Florence Dunes, Mount Hood area, and Tillamook State Forest.
Have a few new toys to play with and to add to the truck.
1 - 16 of 16 Posts
