I continue to have issues on cold starts. Start truck up in the morning or after sitting for more than 4 hours and it will surge from 750 rpm to 1000rpm.
From what ive done, found, tried:
-Fuel isnt the issue. Tried 15 different diesel stations. Tested 3 different diesel fuels from my own tank to determine if there is water in the fuel. Nothing wrong with the stations fuel in the tank but truck still surges.
-Diesel conditioner, anti-gel(both Diesel Power Services and Howes), 911 fuel stabilizer/anti-gel all do nothing to help the surge issue.
-Fuel filters may be clogged with water....no, replaced them every 5k miles from 35k miles to my now 45k miles with no change.
-High Idle switch in info screen does nothing. On/Off/Not selected makes zero difference in the idle quality.
-When the truck comes up to temp the idle will settle at the 3rd mark under 1000rpm and hold there like normal.
-Dealer has reflashed the truck 5 times with no change in idle quality when cold.
-No CEL, no stored codes, no indication lights. Nothing to lead me or the techs in any direction.
-Will do it whether i use the remote start, the key waiting for the glow plug light to go out, or with the key and just starting the thing. It all does the exact same thing.
-Truck drives fine once its warmed up. Idle surge does not happen over 45F.
I'm at my wits end with this truck. Issue after issue after issue keep popping up and the thing only has 45k miles on it.
Does anyone have a GM contact that wants to help get things looked into? I complained to Chevy Customer Care, they opened a case then its been crickets since. No call backs, no emails and no knowledge of any case with the dealer.
