1 - 1 of 1 Posts
Chevrolet : Colorado 2WD Crew Cab 140.5" LT Chevrolet Colorado 2WD Crew Cab 140.5" LT
Located in
[size=+2]Chevrolet : Colorado 2WD Crew Cab 140.5" LT Chevrolet Colorado 2WD Crew Cab 140.5" LT New 4 dr Truck Automatic Gasoline 3.6L[/size]
CLICK HERE TO VIEW THE PRICE
CLICK HERE FOR MORE PICTURES
Rick Hendrick Chevrolet of Buford 4490 S. Lee St Buford, GA 30518 888-266-3606 EBizAutos* 2015 Chevrolet Colorado 2WD Crew Cab 140.5" LT Truck Chevrolet Colorado 2WD Crew Cab 140.5" LT PHOTOS PHOTOS REQUEST MORE INFO VIN: 1GCGSBE33F1208593 Stock #: F1208593 Condition: New Transmission: 6 Spd Automatic Engine: 3.6L V6 CYLINDER Drivetrain: Rear Wheel Drive Exterior Color: BLK Interior Color: JET BLK CLOTH PHOTO VIEWER VIEW OTHER AUCTIONS EMAIL A FRIEND MORE DETAILS Additional Photos Vehicle Overview Black exterior and Jet Black interior, 2WD LT trim. Aluminum Wheels, Bed Liner, Head Airbag, Onboard Communications System, Back-Up Camera, BED LINER, SPRAY-ON, BLACK, REAR AXLE, 3.42 RATIO, Trailer Hitch. EPA 26 MPG Hwy/18 MPG City! KEY FEATURES INCLUDE Back-Up Camera, Onboard Communications System, Aluminum Wheels Keyless Entry, Steering Wheel Controls, Electronic Stability Control, Bucket Seats, 4-Wheel ABS. OPTION PACKAGES BED LINER, SPRAY-ON, BLACK, DIFFERENTIAL, AUTOMATIC LOCKING REAR, TRAILERING PACKAGE, HEAVY-DUTY includes trailer hitch and 7-pin connector, TRANSMISSION, 6-SPEED AUTOMATIC, HMD, 6L50 (STD), REAR AXLE, 3.42 RATIO, ENGINE, 3.6L SIDI DOHC V6 VVT (305 hp [229 kW] @ 6800 rpm, 269 lb-ft of torque [365 N-m] @ 4000 rpm) (STD), LT PREFERRED EQUIPMENT GROUP includes standard equipment, AUDIO SYSTEM, CHEVROLET MYLINK, 8" DIAGONAL COLOR TOUCH WITH AM/FM/SIRIUSXM USB ports, auxiliary jack, Bluetooth streaming audio for music and most phones, hands-free smartphone integration, Pandora Internet radio, voice-activated technology for radio and phone (STD). 2WD LT with Black exterior and Jet Black interior features a V6 Cylinder Engine with 305 HP at 6800 RPM*. EXPERTS ARE SAYING Great Gas Mileage: 26 MPG Hwy. BUY FROM AN AWARD WINNING DEALER We want to be your car dealer-please tell us how! Horsepower calculations based on trim engine configuration. Fuel economy calculations based on original manufacturer data for trim engine configuration. Please confirm the accuracy of the included equipment by calling us prior to purchase. Features & Specifications Standard Features* – MECHANICAL Engine, 3.6L SIDI DOHC V6 VVT (305 hp [229 kW] @ 6800 rpm, 269 lb-ft of torque [365 N-m] @ 4000 rpm) (Standard on Crew Cab Long Box models.) Transmission, 6-speed automatic, HMD, 6L50 Rear axle, 3.42 ratio (Requires (LFX) 3.6L SIDI DOHC V6 engine. Standard on Crew Cab Long Box models.) GVWR, 5800 lbs. (2631 kg) (Standard on Crew Cab models with (LFX) 3.6L SIDI DOHC V6 engine only.) Rear wheel drive Brakes, 4-wheel antilock, 4-wheel disc Vehicle Name : Chevrolet Colorado Body Style : Crew Cab Pickup Body Code : E63 Drivetrain : Rear Wheel Drive Number of Passenger Doors : 4 Gross Axle Wt Rating - Front (lbs) : 3200 Gross Axle Wt Rating - Rear (lbs) : 3500 Gross Vehicle Weight Rating Cap (lbs) : 5800 Maximum Trailering Capacity (lbs) : 3500 Engine Order Code : LFX Engine Type : Gas V6 Displacement : 3.6L/217 Fuel System : Direct Injection SAE Net Horsepower @ RPM : 305 @ 6800 SAE Net Torque @ RPM : 269 @ 4000 Trans Order Code : MYB Trans Type : 6 Trans Description Cont. : Automatic First Gear Ratio :)1) : 4.06 Second Gear Ratio :)1) : 2.37 Third Gear Ratio :)1) : 1.55 Fourth Gear Ratio :)1) : 1.16 Fifth Gear Ratio :)1) : 0.85 Sixth Gear Ratio :)1) : 0.67 Reverse Ratio :)1) : 3.20 Transfer Case Model : N/A Suspension Type - Front : Independent Suspension Type - Rear : Multi-leaf Axle Ratio :)1) - Rear : 3.42 Steering Type : Pwr Rack & Pinion Turning Diameter - Curb to Curb (ft) : 44.6 Brake Type : Pwr Brake ABS System : 4-Wheel Disc - Front (Yes or ) : Yes Disc - Rear (Yes or ) : Yes Front Brake Rotor Diam x Thickness (in) : 12.2 x 1.0 Rear Brake Rotor Diam x Thickness (in) : 12.8 x 0.7 + EXTERIOR Wheels, 17" x 8" (43.2 cm x 20.3 cm) Blade Silver Metallic cast aluminum Tires, P255/65R17 all-season, blackwall Pickup box Tire, spare P265/70R16 all-season, blackwall (Included and only available with (S1K) 16" x 7" (40.6 cm x 17.8 cm) steel spare wheel.) Wheel, spare, 16" x 7" (40.6 cm x 17.8 cm) steel (Included and only available with (LFX) 3.6L SIDI DOHC V6 engine. Standard on Crew Cab Long Box models.) Bumper, rear body-color CornerStep, rear bumper Moldings, Chrome beltline Headlamps, halogen with automatic exterior lamp control Cargo box light, back of Cab Mirror, spotter, located in corner of driver-side outside mirror Mirrors, outside power-adjustable, body-color, remote, manual-folding Glass, windshield shade band Handles, door release, front and rear, chrome Door handles, body-color Tailgate, locking Tailgate handle, Black Front Tire Order Code : QHR Rear Tire Order Code : QHR Spare Tire Order Code : ZJJ Front Tire Size : P255/65R17 Rear Tire Size : P255/65R17 Spare Tire Size : P265/70R16 Front Wheel Size (in) : 17 x 8 Rear Wheel Size (in) : 17 x 8 Spare Wheel Size (in) : 16 x 7 Front Wheel Material : Aluminum Rear Wheel Material : Aluminum Spare Wheel Material : Steel Wheelbase (in) : 140.50 Length, Overall w/o rear bumper (in) : 224.90 Width, Max w/o mirrors (in) : 74.30 Height, Overall (in) : 70.60 Overhang, Front (in) : 36.90 Overhang, Rear w/o bumper (in) : 47.20 Ground Clearance, Front (in) : 8.10 Ground Clearance, Rear (in) : 8.10 Cargo Box Length @ Floor (in) : 74.00 Cargo Box Width @ Floor (in) : 57.80 Cargo Box Width @ Wheelhousings (in) : 44.40 Cargo Volume (ft3) : 49.90 + ENTERTAINMENT Audio system, Chevrolet MyLink, 8" diagonal Color Touch with AM/FM/SiriusXM USB ports, auxiliary jack, Bluetooth streaming audio for music and most phones, hands-free smartphone integration, Pandora Internet radio, voice-activated technology for radio and phone Audio system feature, 6-speaker system Audio system feature, USB port, located on instrument panel Audio system feature, USB port, located inside center console SiriusXM Satellite Radio is standard on nearly all 2015 GM models. Enjoy a 3-month All Access trial subscription with over 150 channels including commercial-free music, plus sports, news and entertainment. Plus you can listen to SiriusXM Internet Radio everywhere on your computer, smartphone or tablet. Welcome to the world of SiriusXM. (If you decide to continue listening after your trial, the subscription plan you choose will automatically renew and you will be charged according to your chosen payment method at then-current rates. Fees and taxes apply. To cancel you must call us at 1-866-635-2349. See our Customer Agreement for complete terms at www.siriusxm.com. All fees and programming subject to change.) OnStar with 4G LTE provides a built-in Wi-Fi hotspot to connect to the internet at 4G LTE speeds (Visit www.onstar.com for vehicle availability, details and system limitations. Services and connectivity may vary by model and conditions. 4G LTE service available in select markets. 4G LTE performance based on industry averages and vehicle systems design. Some services require data plan.) + INTERIOR Seats, front bucket Seat adjuster, driver 4-way power with manual recline Seat adjuster, passenger 2-way manual fore/aft with manual recline Seat, rear folding bench (Crew Cab models only.) Console, floor, front compartment, custom Charging ports, 2, USB, located on the rear of the center console Floor covering, color-keyed carpeting Floor mats, carpeted front Floor mats, carpeted rear Steering wheel, leather-wrapped Steering column, tilt and telescopic Steering wheel controls, mounted audio controls Display, driver instrument information enhanced, one color Windows, power with driver Express-Up and Down Cruise control, electronic, automatic Door locks, power Remote Keyless Entry, extended range Theft-deterrent system, immobilization Theft-deterrent system, unauthorized entry Air conditioning, single-zone manual climate control Mirror, inside rearview manual day/night Console, overhead Visors, driver and front passenger illuminated sliding vanity mirrors, covered Lighting, interior, dual reading Lighting, interior, roof, rear courtesy and dual reading lights (Crew Cab models only.) Passenger Capacity : 5 Total Cooling System Capacity (qts) : 15.6 Front Head Room (in) : 41.40 Front Leg Room (in) : 45.00 Front Shoulder Room (in) : 57.50 Front Hip Room (in) : 55.00 Second Head Room (in) : 38.30 Second Leg Room (in) : 35.80 Second Shoulder Room (in) : 56.20 Second Hip Room (in) : 53.30 + SAFETY StabiliTrak, stability control system Traction control, electronic Daytime running lamps Air bags, dual-stage frontal and side-impact, driver and front passenger and head-curtain and seat-mounted side-impact, front and rear outboard seating positions with Passenger Sensing System (Always use safety belts and child restraints. Children are safer when properly secured in a rear seat in the appropriate child restraint. See the Owner's Manual for more information.) OnStar Directions and Connections plan for 6 months including Automatic Crash Response, Stolen Vehicle Assistance, Roadside Assistance and Turn-by-Turn Navigation (Visit www.onstar.com for vehicle availability, details and system limitations. Services may vary by model and conditions.) OnStar Basic plan for 5 years including RemoteLink Key Fob Services, OnStar Vehicle Diagnostics and Dealer Maintenance Notification (Access is available for 5 years from the date of vehicle delivery, and is transferable. Does not include emergency services. To cancel RemoteLink Key Fob Services or if your vehicle is sold, contact an OnStar Advisor. See www.onstar.com/mobile for full details.) Rear Vision Camera with dynamic guide lines Tire Pressure Monitor System + EPA Fuel Economy & Specification Curb Weight - Front (lbs) : - TBD - Curb Weight - Rear (lbs) : - TBD - EPA Greenhouse Gas Score : 5 Fuel Economy Est-Combined (MPG) : 21 EPA Fuel Economy Est - City (MPG) : 18 EPA Fuel Economy Est - Hwy (MPG) : 26 Tons/yr of CO2 Emissions @ 15K mi/year : 8.5 Gross Combined Wt Rating (lbs) : - TBD - Dead Weight Hitch - Max Trailer Wt. (lbs) : - TBD - Dead Weight Hitch - Max Tongue Wt. (lbs) : - TBD - Wt Distributing Hitch - Max Trailer Wt. (lbs) : - TBD - Wt Distributing Hitch - Max Tongue Wt. (lbs) : - TBD - Cold Cranking Amps @ 0* F (Primary) : - TBD - Maximum Alternator Capacity (amps) : - TBD - Maximum Alternator Watts : - TBD - Frame Type : - TBD - Spring Capacity - Front (lbs) : - TBD - Spring Capacity - Rear (lbs) : - TBD - Axle Type - Front : - TBD - Axle Type - Rear : - TBD - Axle Capacity - Front (lbs) : - TBD - Axle Capacity - Rear (lbs) : - TBD - Stabilizer Bar Diameter - Front (in) : - TBD - Stabilizer Bar Diameter - Rear (in) : - TBD - Front Tire Capacity (lbs) : - TBD - Rear Tire Capacity (lbs) : - TBD - Spare Tire Capacity (lbs) : - TBD - Revolutions/Mile @ 45 mph - Front : - TBD - Revolutions/Mile @ 45 mph - Rear : - TBD - Revolutions/Mile @ 45 mph - Spare : - TBD - Steering Ratio :)1), On Center : - TBD - Steering Ratio :)1), At Lock : - TBD - Turning Diameter - Wall to Wall (ft) : - TBD - Fuel Tank Capacity, Approx (gal) : 21 Fuel Tank Location : - TBD - Front Bumper to Back of Cab (in) : - TBD - Cab to Axle (in) : - TBD - Cab to End of Frame (in) : - TBD - Ground to Top of Load Floor (in) : - TBD - Ground to Top of Frame (in) : - TBD - Frame Width, Rear (in) : - TBD - Cargo Box Width @ Top, Rear (in) : - TBD - Cargo Box (Area) Height (in) : - TBD - Tailgate Width (in) : - TBD - Ext'd Cab Cargo Volume (ft3) : - TBD - About Rick Hendrick Chevrolet of Buford *Rick Hendrick Chevrolet is a “World Class” Sales and Service center supporting the greater Northeast Georgia area. We are North Georgia’s newest General Motors dealer. Our dealership is a state of the art facility with an upscale sales department, large general service division, a Quick Lube Center, and adjacent collision center. As a member of the Hendrick Automotive Group, we belong to one of the largest and most successful dealer groups in the country. As with any Hendrick dealership, we are committed to you, our customer. Our business philosophy is built around what we call the “Hendrick Advantage”. Our mission is to provide our customers with a dealer experience that is second to none through teamwork, trust and respect, a commitment to customer enthusiasm and accountability at all levels of our business. We are driven for continuous improvement in every facet of our operations and your experience with us will be more of a relationship rather than a transaction. That’s the Hendrick Advantage! We are located just 5 miles west of the Mall of Georgia convenient to Interstate 85 and 985. * BUYER RESOURCES Contact John DeHass for more information Phone:*** 678-394-3072 Request More Info Options & Features Ext / Int Color BLK with JET BLK CLOTH Interior Luxury Features Air Conditioning Cruise Control Leather Steering Wheel Steering Wheel Radio Controls Tire Pressure Monitor Power Equipment Power Driver's Seat Power Locks Power Mirrors Power Windows Safety Features Anti-Lock Brakes Daytime Running Lights Driver's Air Bag Dynamic Stability Control Keyless Entry Passenger Air Bag Roll Stability Control Security System Side Air Bags Side Curtain Airbags Interior Vanity Mirrors Audio / Video AM/FM Bluetooth Factory System Reverse Camera Voice Control Voice Control Additional Features Back-Up Camera, Satellite Radio, iPod/MP3 Input, Onboard Communications System, Trailer Hitch, MP3 Player, Bucket Seats, Bed Liner, Tire Pressure Monitoring System, 4-Wheel Disc Brakes, Locking Rear Differential, Side Head Air Bag, Rear Head Air Bag, Driver Air Bag, Leather Wrapped Steering Wheel, Auto-Off Headlights, Power Driver Seat, Power Driver Mirror, Daytime Running Lights, Adjustable Steering Wheel, Passenger Vanity Mirror, Driver Vanity Mirror, Driver Illuminated Vanity Mirror, Passenger Illuminated Visor Mirror, Front Reading Lamps, Tires - Rear All-Season, Tires - Front All-Season, Front Floor Mats, Full Size Spare Tire, V6 Cylinder Engine Financing Information Contact us today at 678-394-3072 for more information, or fill out our Online Credit Application to begin the pre-approval process today. Warranty Information Hendrick Autoguard - A Higher Level of Protection We are committed to giving you all the options you might need to get maximum value from purchasing or leasing your vehicle! All Hendrick Autoguard vehicle protection programs are available as single products, or value-packaged for added savings. Make your choice based on your specific needs for the protection of your automotive investment. Click here for more information Terms of Sale Overview We reserve the right to end this listing at anytime should the vehicle no longer be available for sale. The following terms of sale apply to all of our listings. Payment Terms: This vehicle may be listed on an eBay online auction. The successful eBay high bidder will submit a $1,000 non-refundable deposit within 2 business days of the close of the eBay auction to secure the vehicle. The eBay buyer agrees to pay remaining balance due (plus applicable fees and taxes) within 3 BUSINESS days of the close of the eBay auction. All financial transactions must be completed before delivery of the vehicle. Payment Methods: Cash (in person), certified check, bank transfers, or 3rd-party financing. Fees and Taxes: $599.00 Dealer Administrative Charge is included in advertised price. All prices and offers are before tax, tag, title, license and mv rights act fee. Out of state buyers are responsible for all state, county, city taxes and fees, as well as title/registration fees in the state that the vehicle will be registered. All prices and offers include all rebates and incentives which the dealer retains unless otherwise specifically provided. Dealer not responsible for errors and omissions; all offers subject to change without notice, please confirm listings with dealer. Out of State Sales: Regardless of your state of residency or physical location, all vehicles shall be delivered at the dealership, but upon your request, the dealership may assist you in arranging to have the vehicle transported by a third party to your location of choice at your expense. Out of state customers shall be solely responsible for state and local taxes due on, and registrations for, all vehicles. Location & Transportation: All vehicles may not be physically located at this dealership but may be available for delivery through this location. Transportation charges are included in the posted price. Please contact the dealership for more specific information. All vehicles are subject to prior sale. Law & Venue: The sale or lease of any vehicle, and any other goods or services provided by the dealership (collectively, a "Transaction"), and all claims and causes of action (whether statutory in contract or tort) that may be based upon, arise out of or relate to such actual or proposed Transaction (including any claim or cause of action based upon, arising out of or related to any representation or warranty made or as an inducement to enter into a Transaction) shall be governed by and construed and enforced in accordance with the internal laws and judicial decisions of the state in which the dealership is located, without regard to conflict of law provisions thereof. Any litigation, action or proceeding arising out of or relating to a Transaction shall be instituted exclusively in any state court in the state and county in which the dealership is located. These Terms of Use are void where prohibited by law, and the right to access this website is revoked in such jurisdictions. Quick Links Warranty Info Financing Info Shipping Info Terms of Sale Rick Hendrick Chevrolet of Buford Buford GA Contact John DeHass Phone: 678-394-3072 Contact John DeHass for more information Phone: 678-394-3072 REQUEST MORE INFO It is the customer's sole responsibility to verify the existence and condition of any equipment listed. Neither the dealership nor eBizAutos is responsible for misprints on prices or equipment. It is the customer's sole responsibility to verify the accuracy of the prices with the dealer, including the pricing for all added accessories. Copyright © 2001-2015 eBizAutos.**All Rights Reserved. * eBay Motors Software*by eBizAutos * Counter Provided by eBizAutos.com
IF YOU ARE INTERESTED IN THIS PRODUCT, CLICK HERE TO BID OR TO BUY IT NOW
1 - 1 of 1 Posts
About this Discussion
1 Participant
Chevy Colorado Parts
Chevy Colorado & GMC Canyon
Full Forum Listing
