1 - 8 of 8 Posts
Has anyone else seen this?
MSRP $150.00*
-Increases front ride height by up to 1 inch
-Levels vehicle stance
-Provides a greater approach angle for increased clearance over off-road obstacles
-Enables the use of popular off-road tire combinations
-Does not void New Vehicle Warranty
-Constructed of e-coated steel (upper spacer) and polyurethane (lower spacer)
-Not available for ZR2 or 2WD models or vehicles with 20-inch wheels
-Kit includes front upper spacers, lower spacers and low profile nuts
I have not, I think most of us buy the level kit from 589fab
comes with spacers, nuts and new bump stop, for about 60 bucks or so..
the rc version is the spacer, and nuts, no bump stop for 50
some buy the readylift version, it raises the front about 2 inches
I have seen it - it was announced a while back. This is probably the one I would buy - as it's OEM parts.
Basically 1/2 a RC kit.
I don't get the "no 2wd" and 20" wheel restriction. Most of the spacer and perch lift/level kits on the market fit 2WD and 4WD, because the UCA's and LCA's, struts and springs are basically the same.
I get that it keeps warranty but will a 1" actually make the Colorado/Canyon level? Reason I ask I have the Rough Country 2" strut/spring combination on my 2019 Colorado 4x4 crew cab and when measure front and back it now sits perfectly level.
That one would take busting the strut/spring assembly down, because of the lower spring insulator.
Can't find a part # for ext cab 4x4 wt ?
it would be the same as the crew cab, here is one that I mentioned, not sure what you are driving, need to put that in your signature , so I put both links
1 - 8 of 8 Posts
