The parts finally came in this morning. When I got home I installed them to confirm everything went together properly. Here are the part numbers from the order and molded into the parts.
84214462 Chrome trim Bezel Left Side
84214463 Chrome trim Bezel Right Side
23248067 Black Bezel Left Side
23248068 Black Bezel Right Side
I accessed the back of the fog light trim by removing seven screws that hold the inner fender panel. I then folded the inner panel back and held it out of the way with a bungy cord. I had a hard time getting the first original bezel removed. Once I figured out how to get it out the second one was somewhat easier. There's probably many different ways of getting the original bezel out but I ended up inserting four screw drivers next to the top and inside tabs and wedging the screwdriver in far enough to force the bezel tab below the bumper cover surround. I then made sure the one bottom tab and two outer side tabs center latch was collapsed. This should free up the bezel and with a little push from the back or a plastic pry tool from the front the bezel came out.
Before installing the new trim, snap the chrome pieces into their respective black bezels. The new assembly snaps in fairly easily. Make sure all tabs are seated.
Hope this gives some insight to those who might want to make this modification. I think it looks pretty good. BTW, the total price for parts was $185.64. If I was sure of the right part numbers, I would have shopped price but as you can see above, two of the part numbers have changed since this thread started.
Howard
