I have owned my 2016 Colorado work truck, with base information system, since new. I again am having problems setting the clock back to standard time, and note the screen has dimmed for unknown reasons.
I had the dealer set the clock when we went to Daylight Saving Time. I recall it was a simple operation. This time I tried for intuitively obvious and again failed. Reading the owner manual it says to use the "settings" from the "Home Page". Doing so by using the touch screen to touch "settings". It allows me only to set radio options and to enter the radio display. I tried rotating the menu knob, and noted the highlight on the "radio" and "setting" icons moved back and forth, not in any way that made it clear which was active. I tired both possibilities, yet I can not get the "settings" to activate a menu that included the clock, and I hope intensity.
Looking for help before I go back to the dealer. The dim display is more troubling to me than the clock being off by an hour. Could the dimming be due to an error in the light detector that automatically turns on the head lights? I assume that set would cause the display to dim.
Jerry in NJ
Jerry in NJ
