Good afternoon, dealing with an on going brake issue on my 2015 Canyon, and disappointment with GM
Had the brake noise common with the twins, sounds like a pads dragging, dealer replaced pads turned rotors, 22,000 miles greater the 7mm pad on front, still had the noise, said its just the way it is.
At 33,000 miles its gotten worse, took it to another dealer front rotors are done, outboard pads less then 1mm inboard 5mm both front brakes, GM dealer says normal wear, and not an issue, aren't covered and the rears need to be replaced too.
Seems like 11,000 miles on a set of brakes is poor at best, 33,000 for all brakes and to burn through a set of rotors too,
I won't bore you with all my vast knowledge on what I think is going on so my question:
Have read a handful of posts and heard that GM has had issues with brakes in the past
Not worth investing in a truck I can not keep brakes on
I live in the mountains and tech says thats why, although our Sierra 1500 has 45,000 on its original brakes
Are the twins, under braked, design problem that i will spend more time chasing then its worth, or something else I am missing?
Trucks parked for the time being I will pull it apart and take pics when i get some time, likely won't be till early November
Thanks in advance!
Thanks in advance!
