Hey guys, I've been having a problem with the right rear brake squeaking. I've taken the truck in 4 times, had the rotors, pads, and hardware replaced and the noise still reappears. After having everything replaced the noise went away for a few days and then came back. It only happens with light brake pressure, and it squeaks with the speed of the wheel. I'm at a loss. It's worth noting that the axle end play is around 1/16 of an inch. I know some end play is normal because of the c-clips, but idk if maybe it's out of tolerance. Problem first appeared around 4000 miles and truck currently has 10000 miles. Anyone know what's going on?
Thanks for reading
Thanks for reading
