I hope someone can offer some advise on this issue.
I have a 2005 Z71 Crew Cab 4WD Colorado. I know I need to change out my front wheel bearings because I'm feeling a bit is vibration in my gas pedal and I pulled a wheel and I have movement in the hub. I also think I have one or both ABS sensors going out and it is causing an ABS fault. The bearing and sensors will be replaced in the next two weeks.
With this said there is something more with the brakes that has me concerned. This a random. Sometimes is happens shortly after I start to drive or sometimes in the middle of driving. Random... I hear what sounds like a pump priming under the dash by the pedals. When I press on the brake the pedal is firm when the noise is happening. Then the sounds stops and the brake goes mushy and I get a ABS fault light and sometimes a brake light. This is what I think..
1. Air in the brake lines?
2. Faulty ABS pump?
3. Faulty ABS module?
Has anyone experienced this pump issue?
The brakes work fine but are mushy I guess they are running on vacuum and the power assist is not working.
Thanks
2. Faulty ABS pump?
Thanks
