Ok, so here are some shots of the custom LED grill light bracket process.
First, let's start with the lights I purchased them on Amazon and can be found Here
These are a direct replacement for Ford Raptor (albeit knockoff) grill lights and I liked the fact that they are smoked so you would have to be looking for them if the vehicle was off. Other Colorado dudes on Youtube and a few on here have just bent some aluminum or bought angle and screwed holes into it. Well, I own a 3d printer so I got to work in Fusion and this was the result.
Here is one of the brackets fresh off the printer. This is printed in PETG so it is UV resistant and has the same properties as ABS with a little less heat resistance but that will not be a problem because it does not start to soften until at least 190f. If I am seeing temps high enough to damage this thing I have much worse things to worry about. I also did a "strength test" by standing on one with the 2 legs down. I am 225lbs and they are just fine.
Here we have the bracket, light, and hardware for mounting the light to the bracket. I wanted to be able to wire up a harness off the truck so that I could solder everything with the exception of the quick disconnect which came with the lights prior to going on. The holes in the bracket are threaded for an M4x0.7 screw. Gladly my printer is very accurate so the threads came out with just the right amount of tightness you want from metal to plastic mechanical bond.
Here is the fully assembled bracket with light, mounting nut, and screw inserted. I ended up switching to pan head mounting screws for a more factory look from above the grill. The screw in the picture is just there to test clearance and to make sure that the mounting nut inside the bracket stays centered during the glue-up.
Here is a side shot of the bracket. As you can see there is a nut sitting inside the bracket. A few drops of superglue were put in here to secure the nut and make a more permanent bond than just friction. This will allow me to drill a hole in the top of the grill and have the lights "hang" down from the top. This is an M5 x 0.8 screw and nut combo. I threw a washer between the head of the screw and the grill plastic on top to spread the load when mounting.
There they are, all mounted up. Look closely. I wanted a stealthed out look when I mounted them and I feel I have achieved that.
Here is a link to a little GIF I posted on Reddit of the lights coming on.
Let me know if you have any questions.
